Tomado de: http://www.strictlyeta.net/
M20 ETA to I 2.8 Liter Engine Conversion
Fred Kim
I. FAQ: Frequently Asked Questions
1.) What is the E to I Conversion?
It's the concept of making a hybrid high horsepower, high torque motor with a flat powerband using the top half of a 325i and the bottom block of a 325e. The idea is to obtain the high end power of a 325i and the low end grunt of a 325e using mostly factory parts.
2.) What parts are needed?
For a complete and detailed list, see page 2. But generally speaking, for an 84-87 325e you need the entire fuel injection system from a 325i as well as the intake manifold, throttle body, and complete cylinder head (with cam, valves, and dual valve springs. However, the stock 325e pistons will not work with the 325i head because of the different design; the 325i has a domed cylinder chamber to match the domed pistons while the eta has a flat cylinder chamber to match the flat pistons. Throw the flat 325e pistons into a 325i head and you have a mismatch that causes a lower compression ratio, and this for this procedure, lowering is a bad thing. So that leaves you with 3 choices:
#1 is to use the pistons from a 1988 528e or 325 (Super Eta), which works fine but has a less than ideal compression ratio of 8.8:1. The good thing is that they are cheap if you can find them, but then again, they are used pistons and they aren't very commonplace since they were only available for one model year.
#2 is to use the 325i pistons and shave the top. 3mm is supposed to be the accepted tolerance with stock 325i rods, though I have also heard 2mm as well. Pete McHenry of Precision Performance Services in Winston-Salem, North Carolina (333) 761-0643 is the pioneer of this conversion and would know this information firsthand, as would Jim Rowe of Metric Mechanic in Richland, Missouri (573) 765-1269. There may be other BMW tuners, technicians, and machinists in your area who know this, so ask around.
#3 is to order a set of custom made pistons from companies such as JE, Arias, Kolbenschmidt, and Wiseco. While this is probably the most expensive route, you can customize exactly what type, compression, and size of piston you want. They can be ordered through a variety of vendors, including Ireland Engineering, Top End Performance, Metric Mechanic, and Redline Racing.
I decided to break the parts by type (coolant, fuel injection, cylinder head, etc), but also by necessity. A "C" means the part is absolutely necesary for the conversion; an "M" means that the part is a maintenance item and should be replaced; an "O" means that the part could be replaced while you're down there, but is not necessary, and a "U" denotes a part that is an upgrade over stock. I've included the approximate prices for both new and used parts, but like old underwear, there are some things that you just don't want second hand, so I've placed an "NR" (as in Not Recommended) in the areas where I don't recommend buying used (1). Other than the custom pistons, I chose not to list aftermarket parts (cam, fuel pressure regulator, injectors, mass air sensor, etc) , so the following parts are all factory issue. However, some factory upgrades are listed.
SHORT BLOCK
(see bottom of page for notes)
DESCRIPTION CODE PART # VEHICLE SOURCE $ NEW $ USED
"Belt, air conditioning" M 64-52-1-466-043 E30 325i or 325e 5.5 NR
"Belt, power steering" M 32-42-1-706-825 E30 325i or 325e 7 NR
"Belt, water pump" M 11-51-1-706-710 E30 325i or 325e 7 NR
Connecting rod set M 11-24-1-284-849/50(2) E30 325e 45 NR
"Crankshaft, 524td" U 11-21-2-242-002/2(3) E28 524td 800 350
"Crankshaft front seal, small" M 11-12-1-285-609 E30 325i or 325e 5 NR
"Crankshaft front seal, large" M 11-14-1-275-466 E30 325i or 325e 5 NR
Crankshaft rear seal M 11-14-1-706-785 E30 325i or 325e 25 NR
Crankshaft rear metal gasket M 11-14-1-432-240 E30 325i or 325e 20 NR
Engine mount M 11-81-1-132-323 E30 325i or 325e 15 NR
Main bearing set M 11-21-1-706-849 E30 325e 75 NR
Oil filter M 11-42-1-266-773 E30 325i or 325e 6.5 NR
Oil pan gasket M 11-13-1-730-234 E30 325i or 325e 10 NR
Oil pressure switch M 12-61-1-730-160 E30 325i 10 NR
Oil pump O 11-41-1-720-898 E30 325i or 325e 120 50
"Pistons, high comp/+1mm bore" C N/A (Aftermarket only) 875 NR(4)
Timing cover (lower) gasket M 11-14-1-720-903 E30 325i or 325e 1 NR
CYLINDER HEAD
"Cylinder head, complete" C 11-12-1-707-032 E30 325i 1500 500
"(if not complete, "
the following parts are needed
Camshaft C/M 11-31-1-716-738 E30 325i 325 100
"Camshaft seal, upper" C/M 11-12-1-285-609 E30 325i 7 NR
"Camshaft seal, lower" C/M 11-12-1-276-518 E30 325i 6 NR
Rocker arm C/M 11-33-1-271-429 E30 325i or 325e 15 NR
Rocker arm eccentric washer C/M 11-33-1-744-354 E30 325i or 325e 2.5 NR
Rocker shaft seals C/M 11-33-1-264-519 E30 325i or 325e 2.5 NR
"Valve, exhaust" C/M 11-34-1-708-896 E30 325i 25 10
"Valve, intake" C/M 11-34-1-708-895 E30 325i 15 10
"Valve spring, 30.2mm" C/M 11-34-1-706-583 E30 325i 4 2
"Valve spring, 20.1mm" C/M 11-34-1-706-584 E30 325i 3 2
Head bolt set (torx)(5) M 11-12-1-726-478 E30 325i or 325e 25 NR
Head gasket M 11-12-1-722-734 E30 325i 25 NR
Timing belt M 11-31-1-469-240 E30 325i or 325e 15 NR
Timing belt tensioner M 11-31-1-468-743 E30 325i or 325e 20 NR
Valve cover U 11-12-1-713-116 E30 325i 120 50
Valve cover breather hose M 11-15-1-708-801 E30 325i 13.5 NR
Valve cover gasket M 11-12-1-730-229 E30 325i or 325e 15 NR
FUEL INJECTION/INTAKE SYSTEM
Air flow meter C 13-62-1-286-615 E30 325i 275 50
Air flow meter U 13-62-1-286-064 E28 535i or 533i (M30) 275 75
Air flow meter boot C 13-71-1-708-800 E30 325i 20 10
ECU (Motronic 1.3) C 12-14-1-730-527(6) E30 325i 450 100
Fuel filter M 13-32-1-270-038 E30 325i or 325e 15 NR
Fuel injection wiring harness C -7 E30 325i 500 75
Fuel injector C 13-64-1-734-776 E30 325i 55 10
Fuel injector C/U 13-64-1-726-988(8) E28 535i 55 10
Fuel injector C/U 13-64-1-730-060(8) E36 325i or 323i 85 20
Fuel injector o-ring M 13-64-1-730-767(9) Any 1.5 NR
Fuel injector rail C 13-53-1-719-981 E30 325i ? ?
Fuel pressure regulator (3.0 bar) C 13-53-1-722-040 E30 325i 55 25
Idle control valve C 13-41-1-433-626(10) E30 325i 115 50
Idle control valve hose C 13-41-1-718-777 E30 325i 8 NR
Intake manifold C 11-61-1-289-210 E30 325i ? 90
Intake manifold gasket (large) C 11-61-1-726-012 E30 325i 5 NR
Intake manifold gasket (small) C 11-61-1-726-010 E30 325i 3 NR
Intake manifold support plate C 11-61-1-708-838 E30 325i 25 20
Throttle body C 13-54-1-716-065(11) E30 325i 175 60
Throttle body gasket C 13-54-1-289-576 E30 325i 3 NR
Throttle body dual vacuum hose C 34-33-1-158-113 E30 325i 20 15
Throttle position switch C 13-63-1-710-559 E30 325i 50 30
EXHAUST SYSTEM
Catalytic converter/downpipes U 11-76-1-716-743 E30 325i 420 100
"Exhaust manifold, front" U 11-62-1-710-834 E30 325i ? 50
"Exhaust manifold, rear" U 11-62-1-710-825 E30 325i ? 50
Exhaust manigold gasket M 11-62-1-728-489 E30 325i or 325e 20 NR
Muffler U 18-10-1-705-783 E30 325i 275 100
Muffler hanger kit M N/A E30 325i 40 NR
Oxygen sensor C 11-78-1-716-114(12) E30 325i 115 NR
ELECTRICAL SYSTEM
Alternator (90 A) C/O 12-31-1-726-603(13) E30 325i 200 125
Distributor cap O 12-11-1-725-070 E30 325i or 325e 50 NR
Distributor rotor O 12-11-1-734-110 E30 325i or 325e 20 NR
Ignition wire set C 12-12-1-720-529 E30 325i 115 70
Reference sensor C 12-14-1-720-852 E30 325i 80 35
Spark plug C W8LCR E30 325i 3.75 NR
3.) If I need the entire top half of a 325i, wouldn't it be easier if I started off with a 325i and throw on an eta crankshaft and some custom pistons?
Yes, but what's the fun in that?
4.) How much is this going to cost me?
Again, for a detailed list see page 2, but assuming that you are doing the same thing I am figure at least $2,500 in parts alone. If you shop around and buy some of the parts used and in good condition, you can save yourself a lot of cash. I am doing much of the labor myself (except the machine work), but if you're handing your car over to a specialist then throw in at least another grand in labor. Also, if you have the entire engine out you may as well change other parts such as the head gasket, timing belt, tensioner, water pump, front/rear engine seals, etc, which is obviously going to cost a few more bucks. Altogether, including machine work, I spent around $3,600.
5.) That's a lot of money. Doesn't Ireland Engineering sell a stroker kit for less than $2,500?
Hey, nobody ever said power was cheap. Yes, Ireland does sell a 2.9 stroker kit for around $2 grand, but it is meant to be used with an existing 325i motor. It doesn't include things such as an intake manifold, fuel injectors, cylinder head, camshaft, wiring harness, or ECU. (Seems kind of expensive now, doesn't it?) But if you already have a 325i and/or want a kit relatively free of hassle, then it may be a good choice.
6.) What about the 88 325/528e "Super Eta"? I hear those are better for the conversion than the 84-87 etas.
That's true because the '88 325's and 528e's already have the 325i cylinder head (though it retains the eta cam and single valve springs), Motronic 1.1, and pistons that will work without any modification. Saves some time and money.
7.) An eta is 2.7 liters. How do I get a 2.8 out of that?
The stock 325e engine displacement is 2693cc and the stock piston bore size is 84 mm. Order custom pistons and specify them to be 1mm overbore (so they are 85 mm) and that will give you a displacement of 2758 cc, which rounds up to 2.8 liters. Going even larger to an 86mm bore would also net a 2.8 liter displacement (2823 cc), though some tuners say that 86mm is too much.
8.) How much power are we talking?
It all depends on the setup. It's tough to talk straight numbers because there is so much variance between engines in terms of modifications, but figure that a conservative 2.7 liter setup with '88 325 pistons and stock 325i fuel injection, cam, and exhaust may yield around 180 horsepower and 190 lb-ft of torque at the crankshaft. Something a little more aggressive, such as a 2.8 liter with custom high compression pistons, larger air flow meter, larger injectors, 524td crankshaft, and mild cam may put out around 205 crank horsepower. Engines that are wildly tuned with a 2.9/3.0/3.2 displacement, mass air conversion, hot cam, open headers, bored throttle body with ported manifold, ported cylinder head with oversize valves, etc will put out more than 220 horsepower, but don't expect to get any insane numbers out of the M20 motor. The important thing here is not so much the raw horsepower numbers but the horsepower and torque curves. On a stock 325i both curves are peaked towards higher RPM, while on a stroker they are not only higher but flatter.
9.) Will the car pass smog?
I did. I had to smog my car with only 300 miles on the new engine because my registration expired, and while the results were higher than the 2.7 eta's emissions, it still passed by a wide margin. The idle results may be higher than what they should be because I had a misadjusted throttle body that caused the idle to be around 1050 RPM instead of the normal 750. But if you have other mods, such as a hotter cam, higher flow injectors, etc then you may not have the same results. To see my smog results, click here. The 2.8i should also pass the visual inspection because it looks completely stock unless you have mods like open headers or an adjustable FPR.
10.) What about gas mileage?
Gas mileage usually drops, though exactly how much depends on how you drive. I used to average about 24.5 mpg in my eta and now I'm averaging about 22 mpg with the 2.8i. However, on a 300 mile all-highway trip, I averaged 28.5 mpg at a steady 75 mph. But if you're that concerned about fuel economy, then you wouldn't be reading this right now, would you?
11.) What else needs to be modified when doing the conversion?
A shorter, numerically higher, differential is also recommended since the end result will be a 325i stroker motor (and the stock 325i came with a 3.73:1 rear end). However, many eta owners who are so accustomed to low revs at highway speeds find that too short and use a 3.46:1 or even a 3.25:1 differential instead. Either a 318i or 325i 7000 RPM tachometer needs to be fitted (unless you like to shift by ear), and it also wouldn't hurt to throw on the 325i exhaust system. Furthermore, I would also invest in some sticky tires and good brakes, otherwise your car may end up like one of those 1960's American suicide machines with 400 horsepower and 4 wheel drums.
12.) Can I do this myself?
It seems that most E30 owners pride themselves as being do-it-yourselfers, but there is a tremendous amount of work involved. If you've never done anything like this before and you don't have a dad/brother/neighbor who's a BMW tech, I'd definitely want a professional handling much of the work. A lot of guys on the Internet will say stuff like, "everything bolts right in and that you can do it in a few hours," but that doesn't cover any of the little things (seals, brackets, sensors, wiring, hoses, lines, etc), and believe me, it takes a lot longer than a few hours. If you are capable and/or adventurous enough to build an engine yourself and you have the proper equipment to do so, be prepared to spend a lot of late nights working in your garage and to drain large amounts of cash from your bank account. Just remember where everything goes
13.) I have an automatic eta. Will this work for me?
I'm not too sure how strong the torque converters are on the ZF 4HP22 autoboxes. It can probably handle a mild 2.7 at the least.
